G
Guest
·Right I can't decide between bc coilovers or kw st x coilovers I know with the kw you have to compress your standard spring to reuse your top rubber mount and with the bc ones you don't it's just a plate however is it a knuckle type hub or is it where the shocker has a sleeve which you have to pry the hub open to get the shocker in then bolt up?
