I have the Eibach sway bars because I was going to go to STX, but have decided to stay in HS. I am running yellow Konis and 200TW tires on lightweight rims and the question becomes which bar do I use?
Traditional wisdom says add a rear bar to a FWD car. Some folks say the FiST will do better with a Front bar. I run small, tight courses and have issues with spinning the inside front tire coming out of corners. A rear bar may help, a front bar may not. BUT A front bar may reduce body roll and also help traction - if I can learn to drive corners properly. It's all so confusing.
What are setup are the folks at Nationals running? What are the pros and cons?
