Not a lot of cars use the 4x108 pattern. The Mini uses 4x100 which is a lot more common. I just did a search to see what cars did come with it. It seems to be more of a European size. In the US the most common cars to have this size seem to be the Focus, Fiesta, and Contour. There's a handful more European cars that have them. Your bet bet is aftermarket.
Audis use 4x108, my '95 90 Quattro Sport had 15x7 4x108 wheels. I found some double-drilled 4x100 / 4x108 wheels which was a good solution as they also fit my Miata.
It might be possible to retrofit Mazda 2 hubs or re-drill the Fiesta hubs for a 4*100 lug pattern but you would have to drill your brake rotors too which could be an issue when you need a replacement.
If the rotors are still floating rotors then the hub would keep them centered and you could just enlarge the lug holes some for the clearance on the rotors.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
Related Threads
Ford Fiesta ST Forum
65.4K posts
13.1K members
Since 2013
A forum community dedicated to Ford Fiesta ST owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
