1 - 9 of 9 Posts
I have so many jokes to make. In order:
1) It's Ford's crotch cam. Very hush hush.
2) It's the summer air intake for the car. The air conditioned air is much cooler than the outside air, enhancing HP and torque because we all know turbos like to suck in cold air at higher RPMs.
3) It's the ST specific potato slicer. ST actually stands for "Sliced Tots".
4) If you take the removable grill off, you can put your...thumb...in there while driving. Very exciting.
5) DO NOT TRY TO REMOVE THE REMOVABLE GRILL.
6) It's a belly button lint cooler for those sweet shirtless nights driving over to Sonic.
7)Please don't bother correcting me on #2. I know.
I hope this helps. It's a good thing these forums exist to help each other out!
Nice, I always thought that it was related to the key sensor.
Sent from mTalk
The key sensor should be where the ignition normally is on a keyed car on the steering column. If your battery dies in your fob, to get the car started you hold it up against that area and it should pick up the key.
1 - 9 of 9 Posts
